ผู้เขียน หัวข้อ: Order Glycerin quickly and at great prices Call 034854888 or 0893128888  (อ่าน 1868 ครั้ง)
  • กระทู้: 5415
« เมื่อ: วันที่ 26 กันยายน 2025, 23:42:40 น. »
You can purchase glycerin for soap making here.
จำหน่ายกลีเซอรีน, ผลิตกลีเซอรีนบริสุทธิ์, นำเข้า-ส่งออก กลีเซอรีนเกรดยูเอสพี,
โรงงานผลิต Glycerine, Refined Glycerine, Glycerine USP ราคาส่ง
Glycerin USP Grade, Glycerine USP Grade EP Grade,
Glycerin EP Grade Pharmaceutical Grade Glycerin,
Pharmaceutical Grade Food Grade Glycerin,
Food Grade Vegetable Glycerin, Vegetable Glycerin Thailand Glycerin,
Thailand Glycerin Glycerin Production, Glycerin Distribution,
Glycerin Factory, Glycerin Export, Glycerin Import, Thailand Glycerin,
Thai Glycerin, Thai Glycerin , Pure Glycerin,
Natural Glycerin, Glycerin Product Information
กลีเซอรีนเกรดยูเอสพี , กลีเซอรีน, กลีเซอรีนบริสุทธิ์,
Glycerine, , Refined Glycerine, Glycerine USP
Glycerin, Pure Glycerin, USP Grade Glycerin,
Thai Poly Chemicals Company (Food Additive )
Tel No: 034854888[/color ]
GLYCERINE_TPCC 2026_BY PKSN
Glycerin is a chemical substance that is non-toxic. It has a physical form of a viscous liquid, is colorless, and odorless, but has a sweet taste. It is edible and dissolves well in water and alcohol. Therefore, it can be used as a starting material in the synthesis of a variety of other chemicals. However, it cannot be dissolved in fat.
Glycerin comes in both natural and synthetic forms. Natural glycerin can be extracted from animal fats or vegetable fats such as coconut oil, soybean oil, and palm oil, reacting with water or through a hydrolysis process until the chemical bonds break. Synthetic glycerin can be chemically synthesized from petroleum, propylene, and chlorine. Glycerin is commonly used in many industries because of its diverse chemical properties, especially in the cosmetics and beauty industry. It is used to make shampoos, soaps, toothpaste, lotions, and various skin care products because
glycerin is like a moisturizer that helps increase moisture very well. It is also used in the food industry by acting as a sweetener instead of sugar, a solvent for food coloring, a moisture retaining agent in dried fruits, a preservative, and helps preserve extracts used in spices. Or used as an ingredient in fermentation processes. It is also used in the medical field. It can be used to produce medicines such as suppositories, laxatives, gum disease medications, topical medications, or to make other products such as glue, ink, and explosives. It can be said to be a substance that has many benefits for various manufacturing industries.
กลีเซอรีน, กลีเซอรีนบริสุทธิ์, กลีเซอรีนเกรดยูเอสพี, Glycerine,
บริษัท ไทยโพลีเคมิคอล จำกัด (วัตถุเจือปนอาหาร)
Thai Poly Chemicals Company (Food Additive)
Ultra-pure liquid glycerin. Glycerin can be applied to the face.
Its main properties are to help increase moisture to the skin, reduce dryness,
make the skin look plump, radiant and help strengthen the skin's protective barrier.
However, it is better to use glycerin in skin care products such as moisturizers,
lotions or soaps rather than using pure glycerin to prevent dry or irritated skin.
And always test for allergies before use for safety. You can buy glycerin online
Glycerin, Pure Glycerin, USP Glycerin, Glycerine, Refined Glycerine,
Glycerine USP You can inquire about product information,
request samples and order products at What are the benefits of glycerin?
In skin care Glycerol is a colorless, odorless, sweet liquid that contains alcohol
and hydroxyribonucleic acid. Glycerin comes in both synthetic and natural forms,
with natural glycerin being produced by hydrolysis of animal or vegetable fats.
Hydrolysis When a substance reacts with water, the chemical bonds break down.
Synthetic glycerin is produced through a chemical process involving petroleum,
propylene, and chlorine. Benefits of glycerin for the skin Glycerin helps maintain youthful skin.
Glycerol helps to trap moisture in the skin, giving it a radiant glow and can help reduce
the appearance of wrinkles. Because glycerin helps improve cell growth,
it can slow down premature aging. Glycerin for sale Glycerin helps to moisturize the skin,
acting like a sponge that draws moisture from itself and also helps to slow down
the evaporation of water from the skin. Glycerin for sale helps protect the skin,
especially during cold weather when the skin becomes dry and flaky.
Glycerin works to retain moisture in the skin and protects it from wind and cold weather.
Glycerin is produced for its healing benefits in cases of cracked or psoriasis skin.
Applying glycerin promotes skin health by improving skin function, speeding up
the healing process, and protecting the skin from irritants. Nourishing the skin
with glycerin can also help reduce the chances of acne. Because glycerin is an oil-free ingredient,
when used as a skin care product it does not clog pores, which is a major cause of acne.
Glycerin is gentle on the skin and can be used to exfoliate, cleanse and moisturize the skin without causing irritation. It also helps to gently protect the skin. Glycerine, Refined Glycerine, Glycerine USP Glycerin is a natural extract that is a clear, colorless, odorless liquid with a sweet taste and neutral pH. It has the property of absorbing moisture in the surrounding air very well (Humectant). Wholesale glycerin production, glycerin distribution, Thailand glycerin factory, wholesale price Pure glycerin is a type of alcohol. It is a colorless, odorless, viscous liquid with a sweet taste. Glycerin absorbs moisture when exposed to air. Glycerine for sale. We produce USP grade glycerin. It can be used as a raw material or additive in the pharmaceutical industry.
Glycerine, Refined Glycerine, Glycerine USP. Glycerin can be added to food and used to make soap, hand sanitizer, slime. Glycerine. Pure glycerin production, pure glycerin distribution, pure glycerin import, pure glycerin production factory, pure glycerine (USP Grade).
กลีเซอรีน เกรดยูเอสพี, Glycerine USP Grade
กลีเซอรีน เกรดอีพี, Glycerine EP Grade
กลีเซอรีน เกรดยา, Pharmaceutical Grade
กลีเซอรีน เกรดอาหาร, Food Grade
กลีเซอรีน จากพืช, Vegetable Glycerine
ไทยแลนด์ กลีเซอรีน, Thailand Glycerine
ผลิตกลีเซอรีน, จำหน่ายกลีเซอรีน, โรงงานกลีเซอรีน,
ส่งออกกลีเซอรีน, นำเข้ากลีเซอรีน, ไทยแลนด์กลีเซอรีน,
ไทยกลีเซอรีน, กลีเซอรีนไทย, กลีเซอรีนบริสุทธิ์,
กลีเซอรีนธรรมชาติ, ข้อมูลผลิตภัณฑ์ กลีเซอรีน
กลีเซอรีน (Glycerine) หรือ กลีเซอริน (Glycerin) คือ สารเคมีชนิดหนึ่ง ที่ไม่มีสารพิษ มีลักษณะกายภาพเป็นของเหลว มีความหนืด ไม่มีสี ไม่มีกลิ่น แต่มีรสหวาน สามารถรับประทานได้ ละลายได้ดีในน้ำ และแอลกอฮอล์ จึงนำไปใช้เป็นสารตั้งต้นในการสังเคราะห์สารเคมีชนิดอื่น ๆ ได้หลากหลาย แต่จะไม่สามารถละลายได้ในไขมัน โดยกลีเซอรีน มีทั้งชนิดที่ได้มาจากธรรมชาติ และมาจากการสังเคราะห์ สำหรับกลีเซอรีนธรรมชาตินั้น สามารถสกัดได้จากไขมันสัตว์ หรือไขมันพืช เช่น น้ำมันมะพร้าว น้ำมันถั่วเหลือง น้ำมันปาล์ม มาทำปฏิกิริยากับน้ำ หรือกระบวนการไฮโดรไลซิส จนพันธะเคมีเกิดการแตกตัว ส่วนกลีเซอรีนสังเคราะห์ จะสามารถสังเคราะห์ทางเคมี ได้จากปิโตรเลียม โพรพิลีน และคลอรีน กลีเซอรีน นิยมนำมาใช้ในหลายอุตสาหกรรม เนื่องจากมีคุณสมบัติทางเคมีที่หลากหลาย โดยเฉพาะอุตสาหกรรมเครื่องสำอางและความงาม ใช้ทำแชมพู สบู่ ยาสีฟัน โลชั่น รวมถึงผลิตภัณฑ์บำรุงผิวต่างๆ เพราะกลีเซอรีนเป็นเหมือนมอยส์เจอไรเซอร์ ช่วยเพิ่มความชุ่มชื้นได้เป็นอย่างดี นอกจากนี้ยังนำมาใช้ในอุตสาหกรรมอาหาร โดยทำหน้าที่เป็นสารให้ความหวานแทนน้ำตาล เป็นตัวทำละลายสีผสมอาหาร เป็นสารกักเก็บความชุ่มชื้นในผลไม้แห้ง เป็นสารกันบูด และช่วยถนอมสารสกัดที่นำมาทำเครื่องเทศ หรือใช้เป็นส่วนประกอบในกระบวนการหมัก อีกทั้งยังใช้ในวงการแพทย์ โดยนำไปใช้ผลิตยา เช่น ยาเหน็บทวาร ยาระบาย ยารักษาโรคเหงือก ยาทาเฉพาะที่ หรือนำไปใช้ทำของใช้อื่นๆ เช่น กาว น้ำหมึก และระเบิด ได้อีกด้วยเป็นต้น เรียกได้ว่าเป็นสารที่มีประโยชน์มากมายต่ออุตสาหกรรมการผลิตต่าง ๆ
กลีเซอรีน มีประโยชน์ต่อผิวอย่างไร
กลีเซอรีน คือ สารที่ไม่มีพิษ ลักษณะเป็นของเหลวหนืด ไม่มีสี ไม่มีกลิ่น รสชาติหวาน มีคุณสมบัติที่สำคัญหลายประการต่อการบำรุงผิว ไม่ว่าจะเป็น เพิ่มความชุ่มชื้นให้กับผิว ช่วยให้ผิวแลดูอ่อนวัย ริ้วรอยแลดูจางลง ช่วยปกป้องผิวจากอากาศแห้งเย็น และเป็นเกราะป้องกันมลภาวะต่างๆ ที่จะเข้ามาทำให้ผิวเกิดการระคายเคืองได้ ช่วยเร่งกระบวนการสมานผิวที่แห้งแตก ช่วยปลอมประโลมผิว ลดโอกาสการเกิดสิว ไม่ทำให้รูขุมขนอุดตัน และไม่ก่อให้เกิดการระคายเคือง ทั้งนี้การใช้กลีเซอรีนไม่ควรใช้โดยตรงกับผิวหนัง ควรใช้เป็นผลิตภัณฑ์ที่มีส่วนผสมของกลีเซอรีนแทน และถึงแม้ว่าจะเป็นสารที่ค่อนข้างอ่อนโยน มีความปลอดภัย แต่การใช้ผลิตภัณฑ์ที่มีกลีเซอรีนเป็นส่วนประกอบอาจมีผลข้างเคียง หรืออาการแพ้เกิดขึ้นได้ หากใช้แล้วมีอาการคัน มีผื่นแดง ผิวหนังระคายเคือง ผิวหนังบวมอักเสบ ควรหยุดใช้ทันที ถ้าหากอาการต่างๆ ไม่ดีขึ้นเป็นเวลาหลายวัน ควรเข้าพบแพทย์เพื่อทำการรักษาก่อนอาการจะรุนแรงมากขึ้น อีกทั้งการเกิดผลข้างเคียง อาจเกิดจากปริมาณความเข้มข้นของกลีเซอรีนที่สูงจนเกินไป โดยปริมาณสัดส่วนที่เหมาะสมจะอยู่ที่ 1-10 เปอร์เซ็นต์ ถึงจะปลอดภัยและเพียงพอต่อการบำรุงผิว
ประโยชน์ของกลีเซอรีน
ใช้เป็นตัวทำละลายในอุตสาหกรรมต่าง ๆ เนื่องจากสามารถละลายในน้ำ และแอลกอฮอล์ได้ดี
สำหรับอุตสาหกรรมเคมี มักใช้สำหรับเป็นสารตั้งต้นในการผลิตสารประกอบโพลิออล (Polyol) สำหรับผลิตโฟม
กลีเซอรีนและกลีเซอรอล ที่มีความเข้มข้นมากกว่าร้อยละ 55 จะมีรสหวานสามารถใช้เป็นสารทดแทนน้ำตาลได้
กลีเซอรีนและกลีเซอรอล ที่เป็นสารจำพวก Hydroscopic มีคุณสมบัติดูดซับความชื้นในบรรยากาศได้ดี จึงนิยมนำมาใช้เป็นส่วนประกอบของผลิตภัณฑ์ที่ต้องการความนุ่ม ความยืดหยุ่น และเป็นครีม เช่น อุตสาหกรรมพลาสติกเพื่อให้มีความอ่อนตัว และยืดหยุ่นได้ดี
ใช้เป็นส่วนผสมของผลิตภัณฑ์เพื่อทำหน้าที่เป็น Thickening agent หรือ Bodying agent เพราะสามารถให้ความหนืดได้ดี
ใช้เป็นส่วนผสมสำหรับผลิตภัณฑ์เพื่อรักษาความชุ่มชื้น เช่น น้ำยาบ้วนปาก, ยาสีฟัน, สบู่ เป็นต้น
ใช้เป็นส่วนผสมของผลิตภัณฑ์ยา อาหาร และเครื่องดื่ม เช่น เป็นสารทดแทนน้ำตาล เป็นต้น
โมโนกลีเซอไรด์ใช้เป็นสารอิมัลชัน และสารเพิ่มความคงตัว
ใช้ฉีดพ่นหรือเคลือบผลิตภัณฑ์ทางการเกษตรเพื่อรักษาความสด ป้องกันการระเหยของน้ำ เช่น ใช้พ่นใบยาสูบ
ใช้เป็นส่วนผสมในผลิตภัณฑ์เครื่องสำอาง เป็นสารอิมัลชัน (Emulsion) ในผลิตภัณฑ์ครีม
ใช้เป็นสารที่ทำหน้าที่รักษาความชุ่มชื้นทั้งในส่วนผสมของผลิตภัณฑ์ และผิวพรรณ เป็นต้น
ชื่อเรียกผลิตภัณฑ์ กลีเซอรีน
กลีเซอรีน (Glycerin) กับ กลีเซอรอล (Glycerol) ด้วยชื่อและการเขียนที่ดูคล้ายคลึงกันอาจทำให้บางคนเกิดความสงสัยว่าเหมือนกันหรือไม่ ต่างกันอย่างไร จริงๆ แล้วทั้งสองถือว่าเป็นสารชนิดเดียวกัน แต่อาจจะมีความแตกต่างกันเล็กน้อยตรงที่ความบริสุทธิ์ของสาร ซึ่งกลีเซอรีนที่ชื่อมักจะคุ้นหูมากกว่า จะมีความบริสุทธิ์ที่น้อยกว่า เนื่องจากมีการเจือปนสารต่างๆ ตัวอย่างเช่น น้ำ สี หรืออื่นๆ และยังใช้เรียกเวลาอ้างถึงสารละลายกลีเซอรอลที่มีน้ำเจือปน ส่วนกลีเซอรอลนั้น จะมีความบริสุทธิ์ที่สูงกว่า อยู่ที่ประมาณ 70-80 เปอร์เซ็นต์ หรืออาจมีความบริสุทธิ์สูงมากกว่า 80 เปอร์เซ็นต์ ก็ได้เช่นกัน นอกจากกลีเซอรีนและกลีเซอรอลแล้ว ยังมีชื่ออื่นที่ถูกนำมาใช้เรียกอีกหลายชื่อ ไม่ว่าจะเป็น propane - 1,2,3 - triol, 1,2,3 – propanetriol, 1,2,3 trihydroxypropane, glyceritol และ glycyl alcohol
ข้อมูลเพิ่มเติมเกี่ยวกับผลิตภัณฑ์ กลีเซอรีน สามารถสอบถามข้อมูลผลิตภัณฑ์ได้ที่ บจก.ไทยโพลีเคมิคอล
More information of Glycerine, please contact Thai Poly Chemicals Company Limited (TPCC)
คำค้นหา : กลีเซอรีน, กลีเซอรีนบริสุทธิ์,
กลีเซอรีนเกรดยูเอสพี, Glycerine, Refined Glycerine, Glycerine USP
High purity glycerin can be used in medicine, food and cosmetics.
Export USP grade glycerin, USP grade glycerin factory.
Import USP grade glycerin, Export USP grade glycerin,
Glycerine USP factory Import Refined Glycerine,
Export Refined Glycerine GLYCERINE Food grade glycerin,
pure glycerin, USP grade glycerin, Glycerine , Refined Glycerine,
Glycerine USP can be used with food contact products
Glycerin Pure glycerin, Refined Glycerine, Glycerine USP
Glycerine has a dilute acid or base.
  • กระทู้: 5415
Re: Order Glycerin quickly and at great prices Call 034854888 or 0893128888
« ตอบกลับ #1 เมื่อ: วันที่ 29 กันยายน 2025, 23:01:34 น. »
  • กระทู้: 5415
« ตอบกลับ #2 เมื่อ: วันที่ 1 ตุลาคม 2025, 20:54:29 น. »
  • กระทู้: 5415
« ตอบกลับ #3 เมื่อ: วันที่ 2 ตุลาคม 2025, 20:22:38 น. »
  • กระทู้: 5415
« ตอบกลับ #4 เมื่อ: วันที่ 3 ตุลาคม 2025, 16:00:21 น. »
  • กระทู้: 5415
« ตอบกลับ #5 เมื่อ: วันที่ 4 ตุลาคม 2025, 22:00:02 น. »
  • กระทู้: 5415
« ตอบกลับ #6 เมื่อ: วันที่ 5 ตุลาคม 2025, 18:12:29 น. »
  • กระทู้: 5415
« ตอบกลับ #7 เมื่อ: วันที่ 6 ตุลาคม 2025, 20:00:11 น. »
  • กระทู้: 5415
« ตอบกลับ #8 เมื่อ: วันที่ 7 ตุลาคม 2025, 19:36:27 น. »
  • กระทู้: 5415
« ตอบกลับ #9 เมื่อ: วันที่ 8 ตุลาคม 2025, 19:10:02 น. »
  • กระทู้: 5415
« ตอบกลับ #10 เมื่อ: วันที่ 9 ตุลาคม 2025, 19:00:53 น. »
  • กระทู้: 5415
« ตอบกลับ #11 เมื่อ: วันที่ 10 ตุลาคม 2025, 22:29:30 น. »
  • กระทู้: 5415
« ตอบกลับ #12 เมื่อ: วันที่ 11 ตุลาคม 2025, 20:26:26 น. »
  • กระทู้: 5415
« ตอบกลับ #13 เมื่อ: วันที่ 12 ตุลาคม 2025, 14:43:02 น. »
  • กระทู้: 5415
« ตอบกลับ #14 เมื่อ: วันที่ 13 ตุลาคม 2025, 16:17:41 น. »
