ผู้เขียน หัวข้อ: Dental Venneers in Bangkok  (อ่าน 381 ครั้ง)
  • กระทู้: 624
« เมื่อ: วันที่ 14 สิงหาคม 2023, 19:46:45 น. »
bright white teeth have beautiful teeth can add charm to a smile as well It also enhances confidence. to impress those who see it But if the teeth have problems such as broken teeth, broken teeth, chipped teeth or yellow teeth Veneer veneer is another widely popular method. These problems can be solved quickly and instantly.
What is enamel?
Veneer, or many people may call it veneer, is the use of special materials that are thin and similar in color to teeth. Stick on the teeth to cover up problems such as unattractive teeth, yellow teeth, uneven teeth surface, broken teeth, crooked teeth, making teeth look naturally beautiful
The veneer will need to be slightly milled to the front of the tooth surface. and may need to remove 0.5-1.0 millimeters of dentin to smooth the teeth After that, it will be attached to the surface of the teeth. It closes the entire front of the tooth close to the edge of the tooth at the gum line. Which is usually done only with 8 front teeth. But it depends on the smile type of the service recipient, how many front teeth will be visible when smiling? This method can decorate the teeth to achieve the desired appearance, regardless of the color of the teeth. shape and size of teeth And must be done by a dentist who specializes in prosthodontics. (dental restoration and cosmetic teeth) only for safety and satisfactory results.
Dental Venneers in Bangkok See more here https://bit.ly/3JKtkqS
